aznboi606
do u have the finishing pics?
I'm guessing he means shift boot/knob all back in it's original position.
Maybe he's mistaking this DIY for a shortened shift lever.I thought that too, but it would look the same as before the installation...
So, just to be sure, this:Great post! this will work with out 8thgen short shifter too.
http://www.corsportusa.com/store/catalog/product_info.php?cPath=1_47&products_id=1876
will work just the same as the CT one? CorSport
Good luck. Pm if help is neededI'm attempting this now!
Got halfway through today before I had to go to a dinner thing, but I'll finish tomorrow morning. Just gotta put everything back together now so that's the easy part.Good luck. Pm if help is needed
To be continued in the next post...
Squiggy,
Awesome write up, thank you for taking the time to do this. I would like to add one thing that worked out really well for me to get these plastic push clips out.
I placed a 5/8" socket over top of the clip (the ring sits nicely on the edges of the socket) and pushed with my finger from the backside of the clip. It popped out real easy. No marring of the the panel or clip!
 ) I will not mess anything up.
 ) I will not mess anything up.Remove the right hand shifter cable.
8. Remove the left hand shifter cable.
Squiggy or anyone else who did this mod...
Could you guide me through the process of removing the the shifter cables as displayed in the pictures below?
I tried to do this as described in the steps from this great DIY.
- move away white plastic piece
- rotate spring loaded black piece (HOW MANY TURNS?)
- slide out shifter cable (HOW DO I DO THIS?)
This seemed difficult to do and I didn't want to mess anything up so I stopped. Everything seemed real snug and the cables seemed real tight from the floor to the white housing. Do I have to worry about the black piece rotating CW after I get it off?
Thanks for your help. I have stopped installation until I feel confident (through your replies) I will not mess anything up.
