How do you get the boot back up and on after doing this? Is it very hard? I need to pull mine down to re-align my shift knob and I'm scared I will mess something up. Thanks!
It will just snap back into place.
Batman900. Hey friend: If I understand your problem, and you want to replace the knob properly, first hand screw the retaining "bolt-sleeve" until it bottoms out on the shifter. Then back it off a little. Then screw the knob down to where you want it, of course close to the bolt sleeve at that point, align the knob numbers by eye, then tighten the bolt sleeve up to it with the open wrench while holding the knob firmly with the other hand. Then it'll be tight. Pull up the plastic sleeve, and Bob's your uncle!What do you mean by remedy the alignment?
Thanks guys for the replies, I tried it that way Colint but the problem I ran into is that the black collar will turn with the shift knob. This is even after I have held it tightly in place with a towel and pliers while screwing the knob onto it. In the end I have scratched the collar all up and the knob still wont stay, so now I'm having to use a ton of thread tape which is kinda ghetto. After seeing this thread I went ahead and ordered a new collar "ouch $35!!" and plan to pull the boot down and do it the way shown in the pics so that I don't have to scratch it up again. I had no idea you could even pull the boot down without having to remove part of the console. Now knowing my luck I will break the boot clips and have to replace that to lol. Good to know it will just snap back into place.
The first time I took off the knob I pretty much strong-armed it by simply turning the knob. It was VERY tight, but eventually came off. It wasn't until I had removed it and went to put it back on that I realized the mechanics of it.
The boot clips shouldn't break, but they will become a little loose on the retainer after repeated removals.
Batman900
Batman900
I know you know this, but for others who may not, the black-ribbed bolt sleeve, I guess that's what you have ordered a new one of, has two flat sides grooved in it for a 12 or 14mm (I forget, maybe 9/16) open end wrench. That gets screwed on by hand and then the shift knob goes on. If you screw the shift knob down onto the sleeve, you'll create problems. Instead, put the sleeve on almost to bottom, screw the knob down where you want it with a little play below, then hand-tighten the black sleeve up to it. Next, use hand pressure to hold the knob in place, put the wrench on it, and tighten, holding the knob in an opposite force. The wrench will immediately tighten up against the shifter threads and you're done. If anyone wants, I can do a short vid.
Tools needed:
9/16 open end wrench
Flat head screwdriver - possibly
1. Remove the shift knob by pulling down on the shift boot. It will not simply pull straight down. I found it is best to pull down and angle it slightly and work it from there. You may find it easier to use a flat head screwdriver and pry the clip loose while pulling it down. Once the boot clip is off, use the 9/16 wrench on the retaining piece for the shift knob. Turn it right to loosen it. Once you have done this, you can turn the shift knob to the left. It will take about a dozen full turns to get it off.
When putting the knob back on, you will want to screw it back on as far as it goes and then position it so the image lines up right. After you do that, then you will want to hold it in place and tighten the retaining ring to keep it in place.
Note:You want this to be tight so it doesn't come loose mid-shift!
Do you have a tutorial for an automatic knob ?
it would be awesome, i litteraly searched all the interweb and i found none. i just hope its possible !That would require owning an automatic! Maybe someone else will notice this thread that has done it before and post something up.
	Where di you go to get that diagram ?I just went to http://www.collegehillshonda.com/
CollegeHillsHonda is a forum sponsor here and always full of helpful information.
