BlacklistRogue
Yes yes it did help. And the bad part is I live in a border city. Plates were from Mexico
Then just ask the Mexican police to find the driver and have them pay for it.......... "O"....SNAP........ That's right it would cost more to pay-off the mexican poilce than it would to buy a new hood.........Yes yes it did help. And the bad part is I live in a border city. Plates were from Mexico
It would be great to see someone, who knows what their doing, create a DIY to show the proper way to repair a paint chip.
Maybe RaskyR1 can help?
Just got my new car and they are already happening!!! My OCD is driving me nuts.
I had the same problem with my paint. Mine is extremely small so i think paint pen is fine. the color matched paint pen, clear coat pen, and primer pen? or just the color matched and clear coat?Ouch! That's a nasty one. sorry man!
That's probably a $500+ fix at a body shop and most likely your deductible is going to be that high. If you go this route don't try to find a shop with the lowest price! Find a reputable shop or you will regret it, trust me!
Personally, I would just order some touch-up paint pens from here and call it a day. You can get the Primer, color, and clear and these are much easier to use then the pen/brush ones you get at the dealer. Done carefully it should look pretty good when your done.
http://www.automotivetouchup.com/paintpen.asp
I also strongly advise against try to wet sand and level unless you are experienced at doing so. I can do a quick search on a few forums and show you dozens of newbs that tried, failed, and basically sanded though their clear coat, thus making it worse.
Hope this helps,
Rasky
Larry did mention on his previous vids that wet sanding is like using a clay bar. You just let it glide. I guess that person pressed the sand paper hard on the paint.
I really like the idea of hole punching the sand paper and gluing that tiny piece on the rubber end of a pencil. It's pretty ingenious.
