How much have you spent on your civic?
323
Modifier
5,245
3,684
Chicago
I havent seen a thread like this here
You can post each item and how much it costs, or just a grand total/estimate, but lets see how much everyone has spent on their civic.
I'll start
Intake - $350
Exhaust - $250
Downpipe - $450
RBC kit - $850
Lights (inside and out) - $600
ABS Dynamics lip - $200
Shift Knob and Boot - $60
Base bushings - $30
Short shift adapter - $40
throttle body spacer - $80
Sportlines - $200
Camber arms - $165
Flashpro - $700
Tune - $250
Tints - $150
Horn Replacement - $60
Lug Nuts - $40
Sway bar - (was a gift, so free for me)$120
backup camera - $40
Misc other - $100
Money made from selling parts - $300
(soon to be more)
Grand total
$4615 - $300 =$4315
I'll be selling my intake and exhaust, as well as OEM headlights and springs, hopefully I can make enough money from those four to buy my new exhaust.
I'll start
Intake - $400
Exhaust - $250
Downpipe - $450
Lights (inside and out) - $150
Shift Knob - $50
Base bushings - $30
Short shift adapter - $50
Sportlines - $200
Camber arms - $145
Flashpro - $700
Tune - $350
Tints - $150
Lug Nuts - $40
backup camera - $40
Plasti dip - $40
Misc other - $30
Grand total
$3215
Curious but with all of your mods an Fp an tune how much whp are you making? I have about the same exact power mods an was curious as to how much I'd be making if I picked up Fp.
wheels - $2900
retrofit - $1300
lug nuts - $70
exhaust - $500
misc - $200
total ~ $4970
and im sure im missing quite a few things
While its not a 9th gen, this is how crazy the mod bug (and repairs) has gotten for my 2007 FG2:
35.00 - 2nd OEM Shift Knob
165.00 - Suede XLR8 Gauge Pod
145.00 - Omni Clutch Master Cylinder
185.00 - OEM 07' FG2 Fog Lights
300.00 - PLX SM-AFR Wideband & DM-100 OLED Gauge
74.89 - Hybrid Racing Shifter Bushings
339.80 - TWM Stage 2 Shift Assembly w/ Red Stitch leather shift boot + Base Bushings
46.95 - Clutch Slave Cylinder speed bleeder, Brake bleeder (x4)
382.00 - CC Stage 2
329.00 - Innovative 60A motor mounts
224.10 - CC Lightweight Flywheel
38.94 - Russell SS Clutch line
3540.00 - CT-Engineering Supercharger w/ 3.6" pulley, 3.15" pulley, FlashPro, 520cc injectors, etc.
307.54 - CT-E idler pulley, belt, a/c spacer, a/c bracket, etc.
85.00 - 2nd idler
20.00 - 2nd tensioner
55.99 - Magnetic Oil Filter Collar
1145 - Go-Power Custom Header (Coated)
650 - Full Race 3" exhaust
30 - Skunk2 oil cap
284.05 - PLX SM-VAC/BOOST + DM-100
28.69 - Blox trans/crankcase bolts
69 - Weathertec visors
16 - Red steering wheel H
105 - Walbro GSS342
300.80 - AEM CAI 21-685
38.23 - AEM pre-filter
1200 - HFP lips
140.25 - Hotchkis endlinks
24.67 - CT-E boost fitting
585 - RPF1s & Hoosier radials
2400 - Advan RZ (shipped)
~750 - 245/35/18 Hankook K110's
130 - Advan Center Caps
107.90 - McGard Lugs
150.85 - Exhaust shielding
62.52 - Catch cans + misc fittings
300 - tune @ RLZ
200 - tune by Vit
44.81 - OEM t/o bearing
252.69 - new OEM steering wheel + other misc.
159 - Progress rear sway
75 - Blox front sway
270 - Skunk2 camber arms
20 - Replacement camber arm joint
59.51 - ingalls camber bolts
60 - 5mm wheel spacers
42.25 - GRFXP order
38.00 - another GRFXP order
40 - Tail overlays
246 - GoPro HD
42.77 - GoPro HD acc.
125.00 - Helm 8th Gen Honda Service Manual (Vol 1 & 2)
1500 - 2nd countershaft, 2nd mainshaft, & 2nd second gear (Bro hook-up @ Honda)
3895 - Albins mainshaft, countershaft, 3.00 1st gear, 2.00 2nd gear, and 4.77 Final
425 - Wilwood BBK and other goodies
450 - CM FX400
250 - Toda timing chain tensioner
100 - Hasport FDRR mount
900 - Go-Power Coilovers
100 - 1st replacement clutch bracket
100 - 2nd replacement clutch bracket
100 - 3rd replacement clutch bracket
90 - OEM all season mats
85 - Trunk tray
200 - Optima YellowTop
1125 - MercRacing Stg 2 Aftercooler
300 - ARC DC2 splitters
170 - 3rd & 4th idler
460 - ID725cc injectors & PnP clips
175 - HID/Projector retrofit project parts
40 - 3rd OEM replacement shift knob
100 - ROP valve cover
175 - EM1 CMC w/ Hybrid clutch line
~600 - Firewall repair (Originating from old Competition Stage 2)
375 - ClutchMasters FX300 (Assumed faulty; turned out not to be - sitting on it for now)
390 - ClutchMasters FX400
260 - Full Race spherical LCA bushings
140 - Hawk HT-10s / F pair
72 - Hawk HP+ / R pair
~775 - 245/35/18 Continental DW's
120 - Goodridge braided brake lines
75 - Centric 120 rear rotors
110 - StopTech Street pads (both axles)
120 - Brembo blank front rotors
640 - Acura TSX front calipers
180 - Acura TL Type S brake master cylinder
42 - ATE SuperBlue brake fluid
100 - Replacement Hasport FDRR 88A mount
400 - Replacement Innovative billet 88A mounts
48 - Moog replacement front endlinks
Total:
31654.20
382.00 - CC Stage 2
85.00 - 2nd idler
30 - Skunk2 oil cap
105 - Walbro GSS342
1200 - HFP lips
300 - tune @ RLZ
200 - tune by Vit
42.25 - GRFXP order
40 - Tail overlays
246 - GoPro HD
450 - CM FX400
85 - Trunk tray
Total:
31654.20
Damn
I'm halfway through the suspension phase of my More $ Than its Worth 91 Si B16 build.
I'm still gathering parts and it should running by SEPT.
Tokico HU2797 HP Front Strut Front-Right $87.61
Tokico HU2798 HP Front Strut Front-Left $87.61
Moog K9814 Fr Left Control Arm with Ball Joint $68.52
Moog K9813 FR Right Control Arm with Ball Joint $68.52
Tokico HU2847 HP Rear Strut $78.93
Moog K80668 Trailing Arm Bushings $54.12
Energy Suspension 16.18102G Master Set $156.73
Moog EV217 Steering Tie Rod End Racks $64.48
Energy Suspension 16.5110G 18mm Front Sway Bar Pivot Bushing Set $12.62
Energy Suspension 16.5112R 15mm Rear Sway Bar Pivot Bushing Set $12.62
Partslink Number HO1087117 OE Replacement Honda Civic Front Bumper Filler $47.00
Moog ES2946L, ES2943R Steering Center Link Tie Rod Ends $78.82
Moog K9385, Front Lower Ball Joints $61.48
90 91 HONDA CIVIC FRONT TURN SIGNAL LENS 33301-SH4-A11 OEM RIGHT $25.06
HONDA CIVIC CRX ANTENNA OEM 08118-SH240AH $20.00
90 91 HONDA CRX FENDER MOLDING PROTECTOR RIGHT OEM $31.59
88-91 Honda Civic hatchback SI Oem taillight set $125.00
88-91 Honda Civic hatchback DX OEM side corner light set $50.00
88-91 Honda Civic hatchback oem DX oem Rear control arms set $39.99
90-91 Honda Civic hatchback oem Front bumper liner set $25.00
Si rear lower control arms $75.00
1 Del-Sol Fat Five center cap $4.00
Honda Tech, Sunroof $200.00
Summit Racing Equipment EBW Green Stuff front pads $72.71
Rebuild steering rack $20.00
Auto Zone, Semi loaded front calipers. $87.38
PepBoys, Heavy Duty Valve Stems 13.09
Econo Paint, Strip Repair Prime Paint Del Sol Fat-5 Rims $90.00
Majestic Honda, DUST SEAL A-B, TIE ROD BUSHING RACK END $55.54
Middle Valley Auto, Lower ball joints, bearing install & 1 hub replacement $43.70
U-Pull-It, 88 CRX front & rear springs shocks
front knuckles with hubs $100.00
Auto Zone, 2 brake rotors 1 front wheel bearing $93.92
Auto Zone, 32mm socket $15.28
U-Pull-It, 88 CRX hood, mirrors, Si 15mm rear swaybar $90.00
Ace Hardware, nuts and bolts $6.23
Auto Zone, Haynes manual $26.54
-->91 Honda Civic Si FREE<--
382.00 - CC Stage 2
85.00 - 2nd idler
30 - Skunk2 oil cap
105 - Walbro GSS342
1200 - HFP lips
300 - tune @ RLZ
200 - tune by Vit
42.25 - GRFXP order
40 - Tail overlays
246 - GoPro HD
450 - CM FX400
85 - Trunk tray
Total:
31654.20
Wtf why not spend that money on a sti or a 370z
I dont think my list is that bad......yet....
Tint- 150
Plasti Dip- 6
Maps/Dome- 14
Reverse Lights/License plate light- 6
Nokya Yellow high beam- 20
DDMTuning HIDs- 48
LEDGlow interior kit- 35
Floormats- 25
License plate frame- 15
So thats just 319. But I'll be getting new wheels and tires soon so that'll add about a thousand. Then suspension whenever I get to it...
382.00 - CC Stage 2
85.00 - 2nd idler
30 - Skunk2 oil cap
105 - Walbro GSS342
1200 - HFP lips
300 - tune @ RLZ
200 - tune by Vit
42.25 - GRFXP order
40 - Tail overlays
246 - GoPro HD
450 - CM FX400
85 - Trunk tray
Total:
31654.20
that thing must be insane i would like to see that puppy!!
