I want to ask if the work emotion xd9 18x10 +18 would fit on a 4dr civic si and I lowered it with eibach sportline. Proximately 1.5 inch drop
EDIT:
Yes. They will fit perfect and look great. Get them.
Mine is about an 1.7 inch drop and 1.3 in the back. Wheel gap is a bout a finger in the front and two in the back. Lol
Natural camber from the drop and 18 inch wheels. Just flush not into stance
He doesn't want to run any camber over stock though. Seems pretty wide for no camber adjustments, no?Swoleluc
18x9.5 +20 should work that's about max tho... maybe 18x10+30 but you gonna be close everywhere :/
ohhh yes sorry 18x8 +35 is the safest you can run with no camber/ no rollHe doesn't want to run any camber over stock though. Seems pretty wide for no camber adjustments, no?
9" wide at the most without fender work. 8.5" wide should not give you a problem. Stick around a +35 offset to be safe. Still might be tight with your drop.
Consult the chart.
