Finally! :P
Wasn't really wanting to quite spend the money yet, but I have the Moog endlinks to install and figured I may as well do them both at the same time.
Finally! :P
How much? Where from?Just ordered a Progress Rear Sway Bar!
The horn's mounting bracket is a ground. See if it's connected well to the frame.
What paint did you use for the calipers?
How do you like the horns? And weird that they don't work with the fob, mine do
What trans fluid did you end up using? Which horn did you go with?
