Turbo+ AWD!!!!!
I rigged the twm knob to fit, I drilled & retapped the honda insert that came with the knob. since I dont have a boot retainer (and not paying $25 for one), I tucked the boot down on the shifter body
Evening People :wave:
JasonPA: Did JasonVA get ahold of you yet??
Sent from my Droid using Tapatalk because I'm a BOSS! ;)
Yes, I'm waiting to see what he'll get for us. Probably gonna be two cabins now :woot:
Looks good.... Sucks about the nail thou
Good thing is that I've never had a tire plug come back on me when I worked as a tech, they work well if you install them correctly. This plug was really tight, so I'm confident that it will hold air well. Actually, the tire wasnt' leaking air, so who knows how long the nail was in there, it only started leaking when I pulled the nail out.
Yea I had that little screw in my tire and when I yanked it out no air came out so I just filled the hole with RTV sealant and its holding fine..
Start my new position tomorrow... Won't be on here wh0ring all day.. What will you all do?! LMAO :rotfl:
I will be around till Tues night when I gotta go back down to my buddies so that I can swap out the axles and do a coolant flush....
Subie activity this week:
  • FREE oil change #3
  • am going to complain about the clutch again (gives resistance when pressed). no pattern to when this happens. I can "fix" it by pressing in the pedal a number of times and the resistance nearly goes away
  • Have a rattle in the rear deck lid. I fixed it with squeezing some napkins into the corner. they will fix it
Yay for sitting at the Navy Exchange waiting to get a new id card. Here's to a productive day. :rolleyes : grumble grumble grumble
I see you're morning has started well! :woot: for laundry and cleaning, NOT :unamused:
