Pauly99to17
I am installing my fog lights and have found a ground bolt on the right side, but can't find one for the left side. Anyone know where there is one located?
No, driver side.By right side. Do you mean passenger side?
THANKS!It's located above the windshield washer reservoir.
The other side does not have a bolt in this location.
Ya , I could do it that way, but would rather not.is it long enough to ground on your battery?
When you mean ground to the battery, do you mean hook the ground wire to the negative terminal?is it long enough to ground on your battery?
Ya, okay. That's what I thought. I have a feeling that the ground i found is okay, but the fuse tap in then engine bay #12 is not correct. I think that one might be the correct one for OEM fogs, but not these aftermarket ones. Will test that ground though to see and rule that out.yes, I was talking about the ground/negative battery terminal.
