- 57,191
- 24,271
Enjoying it more?Just finished my fourth datalog with Vit.
Enjoying it more?
Part throttle tuning?
Pulled out the drain plug to the RBC and put some thread tape around it and put it back in. There was a slight leak. Not enough to drip though. Just need to find the elbow from PRL for the upper coolant hose so I can get the hose off of the intake.
Cleaned my garage today too...
I cant tell...where is that vent? as in, where does it lead?
I bet it's just so that moisture has someplace to vent and mold doesn't build in the trunk if some water gets in there.That is the tail light in the upper right and the wheel well is on the left.
I believe it is right behind the part of the bumper that wraps around the side of the car. The vent and hose are on both sides of the trunk. It is not a filtered vent either. You can actually push the white parts in.
