Killin
@323 Its not even the battery relocation. The two main problems were the clutch line breaking loose and the actual intake intake design is HORRIBLE! (Sorry prl) reason I say this is because when you line up the pipes together it basically looks like its going to slip off. Honestly this intake kit is not a clean intake install And it comes with little to crappy install guide! And you need to cut some of the wire clips to extend the positive connector. Honestly the 8th chassis is much easier then the 9th.
