Pauly99to17
I have a 2012 LX and got the system recharge letter from Honda.Im having battery issues too -_-, had to get my car jumped. So this only applies to Canadian Si's?
My '12 Si battery was dying after 12 months and when I took it in to dealer, they said there were no charging bulletins for my vin. They also ran the lights for 5 mins with engine off. Dead. So they replaced it. To me that means that my car charges ok but the batteries suck. I'll be back every year for 60 mo's (extended warranty) for new batteries, then buy a yellow on my own dime. Because I have flashpro, I don't want them flashing the ecu with an update anyway.The letter posted by another member said it applied to a certain vin range of 2012's. I'm not sure if any 2013 owners have experienced the same thing. Did Acura give you a new battery?
Been about a couple weeks my car has died off and on. I figured it was a battery issue and I went to get it checked several places and my battery rating is still very good. One of the mechanics at the dealership said it might be cause the battery doesn't have enough power to start due to the compression ratio. Idk how much of that I should believe.
Yesterday my car died again, tried to jump it 5 times and no start. When I turn the key, it just makes clicking noises. I just met up with my friends a little bit ago and we checked it. My starter is out. I've been checking online and I can't seem to find actual prices of how much starters cost for our cars. If anybody knows how much they go for, it'd be much appreciated.
Yall should get your starters checked out too..that could possibly be an issue as well!
Mr car has 51.5k on the odo...I just went out of warranty lol. Although there was some talk about the starter being under powertrain warranty?For starters.......... Isn't your car under warranty? I'm guessing
Hopefully it will be able to be covered for warranty repairs...I found out the actual starter assembly costs $470 + tax.Anyway, as far as cost, it could be an electric or mechanical problem which could vary in price.
http://www.collegehillshondaparts.c...arter-motor-assy-sm-74002-mitsuba/31200rx0a01Hopefully it will be able to be covered for warranty repairs...I found out the actual starter assembly costs $470 + tax.
While camping we had to boost a car with speaker wire. If speaker wire can work, then booster cables were not at fault for the car^^ not starting. HahaFYI... "8 gauge" is the minimum (Smaller the #, the thicker the wire).
I Googled to see if a too small wire wouldn't work, but never saw a direct answer.
Nope. Just a 60 (?) I believe (whatever that means). I'm confident that I'll never have battery problems again. Hondas have such a great reputation for starting up in the cold.Hope you got a yellow top for a new batt
