ADExternal
Lvl: 99 Modifier
Hello all, due to high demands for this DIY, I was finally able to compose and make one.
Disclaimer
9thcivic.com may or may not endorse various DIY projects, all DIY projects are purely "at your own risk". If you are at all uncomfortable or inexperienced working on vehicles (especially electronics and mechanical), please reconsider doing the job yourself. It is possible on any DIY to damage your car, void your factory warranty, disable a safety feature, create a hazardous condition, or harm or even kill yourself or others. Examples would be the vehicle failing on you, getting an electric shock, or disabling an airbag etc.
Your dealer or mechanic, or professional audio shop may provide services (and a warranty) for any DIY job posted on these forums. Sometimes, it’s just better to pay to have it done.
FAQs
Q: Can I do this for my 2013 Civic Models?
A: This can be applied to the 2013 civic models as well, just different parts but the concept is fairly the same.
Tools
Required:
- Dremel or cutting tool
- Short Phillips Screw Driver
- Small Flat Screw Driver
- Scissors
Project Parts
Required:
Rubber Grommet - 1/2" Inner diameter
Part Link - http://www.ebay.com/sch/eBay-Motors-/6000/i.html?_from=R40&_nkw=1/2 rubber grommets&_sop=15 or any homedepot/lowels store
Cost: $0.59 - 1.59USD
Shipping /Receiving Time: Varies
Comment(s): I got my grommet at home depot but I know some people prefer online ordering. Just make sure the inner hole diameter is about 3/8" to 1/2".
Black Center Console Shroud
Part Name - 77292-TR0-A51ZD PANEL, CENTER CONSOLE *NH167L* (GRAPHITE BLACK)
Cost: $18.50 - 20.00USD + Tax or shipping
Shipping /Receiving Time: 3-5days
Comment(s): This will replace the gray center shroud and is necessary to have the trim fit into.
Black Gloss Boot Trim
Part Name - 77294-TR0-A51ZA GARNISH, CHANGE LEVER BOOT *NH1L* (LH) (BLACK)
Cost: $19.35 - 21.50USD + Tax or shipping
Comment(s): This part is probably what makes the shifter pops out the most.
Manual Shifter Boot
Part Name -
White Stitching - 77299-TR0-A51ZA BOOT ASSY., CHANGE LEVER *NH167L* (GRAPHITE BLACK)
Red Stitching - 77299-TR7-A51ZA BOOT ASSY., CHANGE LEVER *NH167L* (GRAPHITE BLACK)
Cost: $49.85 - 52.60USD + Tax or shipping
Comment(s): Make sure you order the correct part for their particular stitching color.
Prep Work:
Step one - Rubber Grommet
I cut one side of my rubber grommet to make it easier for the tape to hold it up. You can use scissors to make this trim.
Step two - Shiftboot
The shift boot will come with an attachment that is suppose to go with the manual shift nob. But since we dont have that. you will be removing it by flipping the boot inside out and cutting the ziptie with the scissors. And will end up looking like this.
Step three - Knob and Console Removal
Step four - Trimming the Shift Assembly
Step five - Installing Manual Shift Boot
Coming soon....
Disclaimer
FAQs
Tools
Required:
- Scissors
Project Parts
Required:
Manual Shifter Boot
Part Name -
Prep Work:
Coming soon....
