I think your right @andre12dbsi. Correct me if I'm wrong but if you have Nav, don't you see the back up camera in the Nav system and not in the iMid screen? You only see the backup camera in the iMid screen if you don't have Nav. (I don't have the backup camera so I don't know for sure)This is the screen I get when I follow the same process. I'm guessing it's because I have the Nav.
So that's gotta be why this little trick does't work for everyone.Correct. My backup camera shows up in my Nav screen.
You answered what I was asking.K I don't know all the official fancy terms like some of the people here....
2014 Black Civic Si coupe
I wish I had my new car so I could try it!
I think it's being delivered this week though!![]()
Pickin up the new car on WednesdayK I don't know all the official fancy terms like some of the people here....
I'm really looking forward to the upgrades
R if this will work with 13 navi.Figured it out on my 2014 EX
On the Display audio screen, press and hold home, power and eject for a few seconds. A screen pops up.
Select the bottom option.
Go to gridlines setup
Click on rear camera (forgot the picture for this.) Click either dynamic lines or fixed lines. It makes no difference. Neither lines move while you drive.
Viola! you can now drive around with the backup camera on.
There's some neat stuff in the diagnostics menus if you poke around. Apparently the car has built in GPS. I'm guessing it's part of the safety features to notify the cops if you get in an accident or something
Hope this helped. I'm looking forward to doing this tomorrow on the way to work![]()
Isn't the GPS used for the nag system?
I'm going to try this ASAP (2013 si Navi model) can anyone else confirm that this has worked for them?
Was able to figure it out for us 2012/2013 with navi. Hold map/destination and cancel for 5 seconds. Then choose the bottom of the two options, monitor check, monitor adjustment, rear camera and finally "tuning". You can adjust it up down left and right but no real point.. I did but then just set it right back to default. Only way to get out of these screens is push return on the top right corner, cancel button does nothing. Explore these menus, and from the first screen I mentioned, you can click the bottom of the two options and then push and hold only destination (or possibly map) to get to the "for developer" screen. There's even a screen that tells you your exact gps coordinates and sea level.R if this will work with 13 navi.
