- 57,154
- 24,332
post up the pics!
Just an update.
I installed everything over the last week. Most difficult part for me was routing the cables to/from the radio harness in the back, as I had to route them through the center console (had to take it apart). From there, I used the carpet to hide them and have them feed through the air vent which is located under both front seats, so I didn't had to cut any carpet. I grounded to the inner bolt on the back of the seat rail (I sanded the area very well and used a multimeter to test it). All wires and each amp is located under each seat, with no wires visible and the amps themselves are located so the air hits them so they can get cooled down when under pressure.
Overall I am very satisfied with my install. As others mentioned, the bass produced by the Boss Bass600 is not something you will feel outside but definitely satisfy my needs. If anyone wants any pictures of the install and amp locations, feel free to request them here and I will gladly uploaded them.
Thanks to all who chimed in with your input!
So you did something like this?
I can't really tell from the angle of the picture itself, but it looks pretty close to what I have now! although I see a black wire running from the panels of the center console there (I believe those are speaker wires?). what I did to hide this is that I had to take it apart and run the wires within it and beneath the carpet, so they are not visible at all.
I will try to take some pics later.
