ErckleSi
Ok sweet can't wait to see how it goes
Because I was testing the kit for the 2013 sedan and it was 1k lower but the kmod kit is 85% PRL anyway.... So it was a little bit of a savingI'm just a little curious on why u went with the kmod turbo kit over the prl turbo kit?
Oh wicked ur the tester for the kmod turbo kit for the 13/14 si sedan?Because I was testing the kit for the 2013 sedan and it was 1k lower but the kmod kit is 85% PRL anyway.... So it was a little bit of a saving
Yes kinda but like I said 80% of kmod kit is PRL. The manifold the Downpipe the CAI the dump tube and the turbo all came from PRL. He did the intercooler piping and front mount. I didn't know that until I got it. I would have just done PRL if I had knew that. But his kit makes good power so farOh wicked ur the tester for the kmod turbo kit for the 13/14 si?
And ur saying kmod is better cause its cheeper?
Oh ok I get you now lol. Thanks for the infoYes kinda but like I said 80% of kmod kit is PRL. The manifold the Downpipe the CAI the dump tube and the turbo all came from PRL. He did the intercooler piping and front mount. I didn't know that until I got it. I would have just done PRL if I had knew that. But his kit makes good power so far
Thanks everyone!![]()
This all was possible because of my 3 great and best buddies ever Matt Gibbs which it was his storage unit Ryan Fetrow who did a lot of the work myself which helped along and Steve D aka scuba! Thank you soooo much! The car is running have to change out a coolant line it's leaking and get another gasket for the Downpipe to connect to the exhaust as it has a pretty bad exhaust leak and readjust my waste gate so the dump tube doesn't rub the subframe.
Can't wait to drive it!
That's good to hear u disnt have to drop the subframe! And did you have to tap you oil pan?The install was not a breeze that's for sure. Hahahah but was worth it. We got it done without dropping the subframe that was a huge win!
Nope I didn't drop the frame and I didn't tap the pan either PRL kits have a oil drain kit that doesn't require tapping the panThat's good to hear u disnt have to drop the subframe! And did you have to tap you oil pan?
Damn that's good quality! I'm really undecided lol prl had a damn good turbo kit but merc racing is comming out with a tvs supercharger that claims that it puts out around 400 hpNope I didn't drop the frame and I didn't tap the pan either PRL kits have a oil drain kit that doesn't require tapping the pan
