New Year, New ride... 13' Fit!
Status
Not open for further replies.
Got the angel eye set in place. Had to trim the projectors a little bit so they could fit inside the angel eyes.
Need to find a "constant on" fuse that I can tap into so the angel eyes will stay on when the car is on since I have to remove the stock DRL fuse to make the bi-xenon HID work properly.
Other than that, the whole retro is pretty much go to go into the headlights. I am hoping I don't have to trim the shrouds.
what'd you use to hold the stuff together...jbweld?
The main horn is already done. You can see it there in the middle. The alarm beep just got done now. Although not sure how it will sound. I just use the left over hi-low horn upgrade from the '13 accord I had.
nice work dude!
PS I hate you. You're too fast!
Well, just like anything I mods I do to my car......I have an issue.
The panamera shrouds are too wide and too deep so I need to trim them down some. Nothing horrible but I don't have much room to work with do to the LED rings. I also need to bring the projector forward even after trimming down the shroud.
Looks like my happy arse is riding his bike to Home Depot in the morning to try to find some rubber type spacers. Similar to what the projectors came with.
sucks man. Try the plumbing section. You may be able to use something like a rubber gasket from a tub/sink drain, or stack some rubber gaskets from a toilet tank (if that's not too wide)?
I was thinking the same......Im sure I will find something.
image.jpg Had to sacrifice part of the led ring to get everything to properly work. I'll explain in another post but both headlights are sealed back up and everything will be buttoned up tomorrow.
Looks good from what I see. You obviously had luck at Home Depot?
I did but then that created issues with the bulb not properly seating in the projector.
I can't wait to see how they look lit up.
looks really good man. Did you end up pulling your drl fuse? Morimoto bulbs?
Pulled the DRL fuse and Morimoto bulbs, 5k temp.
Status
