I'm curious, on the CIVIC Trims that have this sensor already, where is OEM location installed?
Thanks.
There is a hole. The plastic bracket clicks into place.Is there a pre-drilled hole for the bracket to fit into the bumper, or did you have to make one?
This diy is to show the outside air temperature. It’s not showing engine temps or whatever.I just wonder, why we can't use already installed sensors instead of additional one. I suppose we have 2 sensors installed (on engine and the radiator I guess, I may wrong. ) which contact the engine water directly. Why we cant use them?
Any good tech know how this mod would have caused a short circuit to the PCM causing a flashing D on the gear indicator, a check transmission on the IMIDI and a "DTC p0966 A/T clutch pressure control solenoid valve B (open or short)"? I followed the instructions in this mod, and am skeptical that this mod caused the issue but that is what the dealership is telling me, that wires from the temp sensor going to pin 8 and 24 must have caused a short to the PCM. They recommend replacing the PCM, an $800 dollar plus fix.
