PainlessCandy
@PainlessCandy I'm pretty sure the K24 has a timing belt, not a chain and a belt won't really stretch.
Um, then what is this chain that links the cam shafts and the driveshaft?
I believe Johnny is correct with the timing belt information. As far as oil starvation, I'm not sure it causes as much damage as people seem to believe if it only happens for a second, at least in my case. I always thought the VTC was on the cam gear itself but I could be wrong. We used to have an old Ford farm truck with a staight 6 in it that had an oil pan leak. Every month at some point it would run dry of oil and start knocking pretty bad, we would drive it 5 miles to the gas station, knocking, put oil in it and the knocking would stop. This happened for like 200k miles until the truck was finally killed by drowning it in a lake... so I'm kind of skeptical of this issue causing any real damage. Would be nice to have more info or perspective on the issue![]()
Mine sounds like this
Good bit of information. Thank you! So that leads me to ask how do we prevent this. And is this the type of damage that after 300k miles may cause something to break? I got the lifetime power train warranty so I don't think I have anything to worry about if it does break. But would like to know if there is anything to watch out for.I am going based off of information that I am getting from actual Honda Technicians that have worked hands-on with these vehicles replacing the exact parts we are talking about. I trust their judgement more than anyone who is making assumptions.
Your comparison is apples and oranges: Ford engines are not built to the same tolerances that Honda engines are, and Honda engines are designed around utilizing oil pressure for just about every function. If nearly every time you start the car you are starving part of it of oil during that key first few seconds when the most wear and tear is being done, I think eventually you are going to start damaging parts that should be oiled but are not. Which parts these are I am unsure of, and am still searching for more specific information. You are correct about the location of the VTC Actuator; Just look back at post #24 in this thread, the video shows very clearly where things are and how they function within that system.
Also, I just called my Service Adviser who confirmed that all Si's since 2006 have been using timing chains exclusively.
I stand corrected.I am going based off of information that I am getting from actual Honda Technicians that have worked hands-on with these vehicles replacing the exact parts we are talking about. I trust their judgement more than anyone who is making assumptions.
This. A lesser version of this. It's started for the first time within the last 2 weeks. But it only happens periodically.
Can you provide evidence that OEM filters are better to go along with this disagreement?
So the answer is no then?Only 30 years of building cars and a few engineering degrees. Good enough for me. Do what you want, bud.
Here is a thread all about it so you can educate yourself @Robotaz : http://honda-tech.com/honda-civic-2006-current-79/oil-filters-honda-2889877/
Your supposed experience and degrees are not quantifiable via your mere words on a forum. Links to evidence is. Anybody that has multiple degrees would understand this concept.
So, you are saying you don't know how to do proper research online. There is plenty of verifiable and quantifiable information online...unless my multiple degrees from a reputable and well regarded university that required me to do considerable amounts of research were earned from one that has lied to me.Links to evidence? I didn't get an education on the Internet little buddy.
