Thanks Webby. I want to bump this pin out schematic. I was able to do my install last weekend. With a little help from a Crutchfield master sheet for dismantling my dash. (Props to guys on live chat to send that to me in less than 5 minutes) The pin out was amazing. I was able to find the remote and sub +/- out with no problems (PRE AMP). I was able to solder (right in the dash) my remote turn on and a set of female RCAs (not a LOC ) to the correct wires. It was a one and done for me. This was my first attempt at a custom box install. I still need to get it tuned...it a touch loud. Anyway, using my factory radio, factory amp for my mids and highs. Everything works as is should
Heres what i used for my RCA's (
http://www.sonicelectronix.com/item_67780_Rockford-Fosgate-RFIF2SW.html) (I simply just soldered the positives and negatives together and then to the sub +/- in the appropriate wire harness., again thank you guys at Crutchfield live chat for that advice too)
