You go from giving the rear passengers a nice Honda seat belt padding to giving them cardboard to sit on!! How rude! Lol but in all seriousness I can't wait to see how this turns out
What material are you going to use for the delete kit? Also I'm assuming you found suitable locations to bolt or screw the kit down?
Ah ok so your going to do a fabric wrap. I only asked cause I've seen people do them on other cars out of things like bamboo.Same materials and color as spare tire trunk cover. Yes! When I have time ill upload a photo with the locations to bolt in. I plan to get really fancy with back panel, so might take a week or so
Seems like a foam seat would weigh less than plywood or whatever wood was used.Wow, thats pretty cool man. Intense mod but I like it. Dry carbon panel at the end?
Also, I think taking that dust buster out of the trunk will lose you about 3lbs or so plus all that reduced noise from it flying around has to be worth it.
I know I've seen something similar on an 8th gen...... WOOD PANELING!
That's exactly what I was thinking. Why take the seat out to reduce weight and then add the weight back with the wood?Seems like a foam seat would weigh less than plywood or whatever wood was used.
Final project will look like this?
no wood. Corrugated plastic panel for back with thin layer of foam padding and carpet. Haven't decided bottom material, will need something strong enough to take small screws for locking clipsWhy not just build a small box over the bracket to cover it up? Should be that much extra work.That's exactly what I'm going for top pic. Simple and light weight. I might get all Martha Stewart with back panel tho. Except with a bracket sticking out of center
