cerezo28
The fuse tap is it from munder the steering wheel or from the engine? Sorry for all the stupid questions.So since You are Independent fog lights are You using a relay?
5 pin switch doesn't fit in 2013? Im pretty sure it does because ive wired ones for others with 2013 and 2014's evenAnyone that actually found a button that fits in the 2013+?
honda didnt make a lot of things to go anywhere hahaThe button that comes in the 2012 kit doesn't fit, i've got it and tried it. Local honda dealer weren't able to help, they say Honda didn't make a switch to go there according to them.
its where i put my entire headlight power cutoff switch. so everything in the headlight turns offThat's exaxtly what I was thinking!
i can run out and get you on this afternoon. not much to see from the outside hahaAny pics? Lol
I ended up buying a 3 pin switch, I installed it in the change slot as well. Loving it lol
Sent from my SM-G925W8 using Tapatalk
