DIY DIY - Honda 5 Pin Magic Switch!
Nix
Jötunn Moderator
VIP Member
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
AP generally seems to be pretty trustworthy in his answers. Wheels and suspension are semi-suspect with "flusher" tendencies.... I do however have to say his electrical stuff is pretty solid from what I can tell. I'd take his word for it. I don't think he'd BS you just for fun.
Also, I like his use of unicorns.
AlienPrime
1,873
Sudbury, Ontario, Canada
Civic Si HFP
2 door Coupe
hahaha flusher :D
Yeahhh unicorns... haha my bad lol
PainIs4ThaWeak
242
Charlotte, NC
RC-F / Accord 6+6
I don't really understand why you would ask a question if you are not going to believe the answer you get unless it is the answer you want. ? I have taken that switch completely apart to its individually pieces. There are no coil windings. AP and @323 have done the same. You can buy one if you like and see for yourself or you might consider that the answer you got is correct.
See, now thats what I was looking for. Agreement on disagreeing.
I'll still be looking into it ;)
FooBird
If the Foo...well, you know. Just wear it.
VIP Member
5,426
Kirkland, WA
Si
The other 5 pin button in the car - the flasher button. Same construction. There is nothing on the piece of plastic switch itself.
Your switch:
The pins:
AlienPrime
1,873
Civic Si HFP
2 door Coupe
sure looks a lot like a coil to me hahahaha!
Whatever he is obviously asking a question he doesn't actually wants the answer to. Just wants to be a :unicorn:
Pauly99to17
6,578
Ville de Quebec
2012 LX
Dyno Blue Pearl Sedan (FB2)
@Pauly99to17 and @AlienPrime you guys are awesome!! Ordered my switch and should be here Thursday! Thanks for all the work you two put into this!
Are you going to solder or going to junkyard for the green plug?
Actually, forget soldering. You should do what @ADExternal suggested: use little pins that slide over the pins.
xXCiviXx
657
Calgary, AB, Canada
Si
I was gunna check out a pick your part that is a couple blocks from the dealership but if I come out empty handed I'll have to look into that. Soldering definitely isn't my strongest skill lol
Pauly99to17
6,578
Ville de Quebec
2012 LX
I think I might have an extra green plug around somewhere. PM me if you don't have any luck finding one.
