AlienPrime
im not sureYa, maybe the contact was so weak and inconsistent that it cause the short. ???
I used an LED strip for console lighting and a single LED bulb for door lighting.
DIY. http://9thcivic.com/forum/threads/door-storage-compartment-lights.6900/
http://9thcivic.com/forum/threads/console-led-lighting.6603/
Ya, you're right. Officially they don't ship to Canada. I called them up and talked to Paul. He's a good guy and found a way. I thinkI paid using Pay Pal if I remember correctly.If you don't mind me asking, how did you get College Hills Honda to ship to Canada?
@CollegeHillsHonda
no, not relay at all.So its basically just a SPST relay w/ built-in SPST switch? ... "Magic switch" my arse! lol
http://www.the12volt.com/relays/relays.asp
Thought there was something in here I wasn't aware of... Though this does give me an idea on wiring an electric water pump while keeping the dash switches OEM style.
... Moving along.
Honda likes to fuckk with their shitt to make you confused as f*ck! Its a standard switch, with different sources to illumination and power + control. Nothing magic about it aside from the fact that nobody wanted/could figure it out on 9thgc at the time i was mod.
We often referred to it as 5 pin magic switch, so that's what i called the thread to tie in the association.
take the switch apart, just normal contacts nothing fancy at all.
Lol you're acting like im aI'm sure they wire a vehicle in order to confuse the user.
So, no coil windings on the 12V side?
I don't really understand why you would ask a question if you are not going to believe the answer you get unless it is the answer you want. ? I have taken that switch completely apart to its individually pieces. There are no coil windings. AP and @323 have done the same. You can buy one if you like and see for yourself or you might consider that the answer you got is correct.Not to say I don't believe you or anything, but I don't.![]()
don't know why itThank. You.
I'll pick one up eventually to inspect myself. Not to say I don't believe you or anything, but I don't.
(I smell 8thcivic)
