I was doing research on the best bonding agent for bonding fiberglass to leather. Contact cement apparently works the best. It apparently works for sagging headliners too, which the M3 has.Any reason why you used contact cement over the 3M spray glue?
I've used the 3M stuff for a few door panels and haven't had issues.
Thanks! Yeah, the 25lb weights came in handy for this job haha.Puttin the 25lbs to good use. Cars coming along man!!!
Thanks man. I wanted to drive it to work today, but when I was bleeding out the air from the cooling system yesterday by squeezing on the top and bottom hoses, the bottom hose decided to crack. Lol. The new hose should arrive tomorrow.Dude you put in serious work. Every day this thread has some major development.
I was doing research on the best bonding agent for bonding fiberglass to leather. Contact cement apparently works the best. It apparently works for sagging headliners too, which the M3 has.![]()
Yeah, it's like 72 hours to completely cure.Gotcha....I just hate how long the set time is on it.
Too expensive at this time. Lol. It will be easier to work on the second time around at least.With what you have torn apart so far, you are well on your way to work on internals...
Sent from my MotoG3 using Tapatalk
