Dagocrazy
Active Member
- 17
- 13
I've got extra plugs and pigtails
I wonder what kind of adapter you would need to hook up the HID. The plug looks different.
Just seen these on eBay with the OEM HID's included. I wanna order them but I'm worried I won't be able to make them work. How much modification is needed?
Truth is aftermarket headlights in general have significantly worse output over oem. Significantly. If you want an actual upgrade, look at installing a h1 mini projector kit from theretrofitsource. It will provide a lot better output over stock or aftermarket headlights.Sure wish they would make some aftermarket headlights for '14-'15 coupes......
Do they have a vendor page? Guess I'll just search, that would be the prudent thing to do...thanks @webbyTruth is aftermarket headlights in general have significantly worse output over oem. Significantly. If you want an actual upgrade, look at installing a h1 mini projector kit from theretrofitsource. It will provide a lot better output over stock or aftermarket headlights.
Would painting the flat part of the housing affect light output with the standard bulbs in place? Wanting to make my housing as black as possible. Would maybe a gloss black work for that area, so it still reflects light?You could paint them. Some have used a high temp flat black, or other high temp paint. Some have done their entire oem chrome housing flat back
the low beam side is the one you'd paint (if you paint anything). If you painted the chrome reflector on the other side you'd lose your high beams. It needs that chrome to reflect the bulb light so you have high beams.Would painting the flat part of the housing affect light output with the standard bulbs in place? Wanting to make my housing as black as possible. Would maybe a gloss black work for that area, so it still reflects light?
	That's what I was trying to find out @webby. Thats what I figured, but wasn't entirely sure. Either way itll be a fun project. Thanks for all the support.That would kill light output if you painted it without a retrofit
I know the curved part needs to stay chrome (no retrofit). What I was asking about is the flat part at the bottomof the reflector (no retrofit)? Would I be able to paint that?
