- 57,122
- 24,253
It looks great. Who's doing the work?
@webbyIt looks great. Who's doing the work?
Hi @webbyLook for a "9006 wire/relay harness". eBay/amazon will have them for like $10 or even less. That will take care of you for wiring.
Order a "h1 hid kit". That will come with hid ballasts which will connect to your wire harness.
I can get you a wiring video or diagram if you're going to plug everything in yourself.
I will do that asap.Yeah a wire brush and paint would work
When turning on the low beam, yes it becomes white. When turning on the turn signal, it blinks in yellow.I expected that bar to be white. Definitely different seeing that in yellow. How are you controlling that light bar? I see it’s both active and inactive with your low beams on?
