- 55,543
- 23,820
Definitely need to make that happen.View attachment 56877 Hey @Tak, I just bought a bunch of parts off eBay ...T25 turbo (spools fast as hell but no top end power), an 8th gen r18 turbo manifold fits on our 9th gens, a bunch of oil feed lines and a universal intercooler kit...had to remove windshield washer pump, AC lines and cut out parts of the front bumper(as you can see, someone else could have probably done better but since its a lot of custom work I wasn't too worried about the bumper..probably will redo the plumping and see if I can get another bumper to fit without cutting) Had to delete EGR as well. Bought a catch can too cause it looks pretty haha. If you want to boost your car, Full race has a template of where to drill into your oil pan for oil drain line and where to pull oil feed from - stock oil pressure sending unit...Currently on 11lbs of boost at 298WHP and 333WTQ at 4700 RPM....cost me around $2500 but could have been way cheaper but it was a lot of trial and error...I will most likely start a build thread soon since work is winding down and I actually have time to be active again lol
