- 56,907
- 24,204
honda msrp is supposedly $7.50
https://www.collegehillshonda.com/product/08798-9031.html
CHH sells it for $6.30
How great?![]()
Actually Your right and Webby is off a bit. The drain plugs all use 1.5 threads, but the top is different 14mm for oil and a 18mm top for the tranny which has a 3/8 head on it. I think Honda wanted to make it stupid proof by using different heads on the bolts. The auto tranny uses the same as manual size bolts which does make sense, its easy to make the same size and helps people from getting screwed up, but on other hand it would seem its not idiot proof either. Remember Albert Einstein everything is relative to other things. how is that for a BOLt teaserOops Webby is right. Idk what I was thinking about must still be hungover from Friday.
Most people just buy two 14x1.5 magnetic bolts. A lot of times you can find them in 2 packs. No reason to have them as different sized heads, unless you want them different for some reason. Usually 2 packs are cheaper. Do whatever you wishYour right and Webby is off a bit
Went to a New Honda dealer and bought 3 qts of Honda MTF came to $25. Price per qt $7.88 perhaps not ripping off customers as much. I saw a brand new Honda R model, nice car but Over $35,000. They had no sticker price on it, I suspect price gouging on the R model. On a Brand new Honda SI $25,400 that's like only a few hundred off. Didn't see any cars that looked like my Honda si 2013. Looks like I paid a great price for mine.I would like the way Honda has it stock, 14mm and 3/8 that way by mistake you fill the tranny then take out the drain plug by accident. The tranny drain plug$8.20 fast shipping is more than the check hole $1.75 coming from china on a slow boat. this has been a bolt experience.![]()
