mySIck
@Bruce Bartlow I believe your address is listed on that.
__________@Bruce Bartlow I believe your address is listed on that.
________________@Bruce Bartlow I do have a lot of plans and the Transmission is on top of my list. I am currently looking at going with mFactory gears 1-6 so I can throw more boost at it.
I ended up going with a K24Z3 for my motor since they are dirt cheap and basically the same exact motor. I swapped my water pump over along with the oil pan due to the TSX and SI having different mount location's. At the moment I am burning oil once I get some time I plan to pull the turbo to check it for any damage or play and if everything looks good I might do the motor rebuild first.
Installed this gauge last night, it's actually pretty nifty. Originally was intended for a different project car, but decided to throw it on my 9th Gen since I would like to monitor Water Temp/Oil Temp/Oil Pressure in the near future.
Long term I would like to do a head swap, but for now I'm enjoying running it on Flex Fuel and hoping to take it to the track this year.Looks good!! What plains do you have for your SI?
Have you followed Harry Sparks build? I know he is working on a head swap for his turbo build. Are you planning to run the K20Z3 head?Long term I would like to do a head swap, but for now I'm enjoying running it on Flex Fuel and hoping to take it to the track this year.
Our weather here in NC has been questionable the past several days. I don't know if it is going to be Cold, Cool, warm or hot outside. But hopefully this weekend is nice I am trying to go to the beach.I put my summer tires on the other day...and now it is going to drop to the low 30s overnight for a few days.![]()
at 17,800 and that was too long. I could see plainly the tranny oil was beat. It shift much better now with fresh Honda tranny oil. I plan on changing the tranny oil now every 7500 or less, its only 2 qts and is easy to change from the top with zero waste.You can ruin summer tires below 32 degrees, I drove with summer tires once below 32 degrees and the car wanted to go off in a ditch. the temp really needs at least 40 degrees to work ok with summer tires or they will never heat up right.I put my summer tires on the other day...and now it is going to drop to the low 30s overnight for a few days.![]()
No ****You can ruin summer tires below 32 degrees, I drove with summer tires once below 32 degrees and the car wanted to go off in a ditch. the temp really needs at least 40 degrees to work ok with summer tires or they will never heat up right.![]()
I sort of follow him, not actively but it's fun to see what he's accomplished. I will be running the K20Z3 head and will probably be working with NA Performance in Ventura.Have you followed Harry Sparks build? I know he is working on a head swap for his turbo build. Are you planning to run the K20Z3 head?
