- 57,135
- 24,320
throttle body has been proven to not be a bottleneck. vitviper did a bunch of dyno tests with various throttle bodies and saw no gains over the stock. Stock flows well.
Doesn't the honda si all ready have some sort of traction control all ready, I notice if its on or off, it does seem to help a bit ? At $600, I think I will pass on this one- more into how a shifter is working, exhaust, CAI and 24mm sway bar. Today is Hondata reflash day big moment in Honda's si like to get rid of carb shifter and speed limiter's.
also installing Michelins full beam windshield wiper rated for 2 million wipes latest model -have not seen these any where but Walmart with a extra set if you write in and say they stink
I am sending the old version back to amazon for a full refund
First pic shows the latest Michelin full beam wiper rated for 2 million wipes, has areo and upgraded mounting and a guarantee if you don't like them get a free one sent to you. much improved over there last model which is using a frame, not rated for wipes, not areo either. These upgraded Michelin wipers are only at Walmart as far as I can tell and have absolute highest tech of any wiper currently being made. They go for $40, the old version was $33 which I am sending back for a refund-nothing to good for amazon
traction control input is in flash pro manager-calibration, it looks like you can set it higher from stock of 2000revs when it starts cutting power while losing traction. Looks like I can control the traction with the tuner Hondata. I did notice it seems easy to drive with the traction control on and it would save some tire rubber and go actually faster with it on some times. You actually have best traction with the tires slipping 10% that's why setting it a little higher isn't a bad idea.
? Very confusing. So you have to buy a flash pro traction controller for that to work-$600 too much for me.what about that button that turns traction control on and off? Doesn't the flash pro has a rpm setting that turns it on 2000rpm or you can adj it higher like 2500 that doesn't work-there is a setting that I saw? Very confusing. So you have to buy a flash pro traction controller for that to work-$600 too much for me.
Yes this is true, the Woffee is back-Started up the black SRT-4 monster today in Carb world,...Oh, so this is sunofwolf's lair.![]()
As the oil company want go Leave your car running all day and put some Black filthy Smoke out of your tail pipe
