Still chasing down heat issues. Noticed that the current ones are up since I put the Noctua cpu cooler on after fan failure with the Cryorig C7. Trying a bigger cooler and a couple of 60mm case fans that I can cram into the Node 202 box. CPU temps were still climbing to 87-90 under stock config, down from 95. We’ll see how the new cooler works. It’s gonna be a tight fit.
