Morning
done
done
Yeah, intake pipe right after the airbox(no pictured in second pic) runs above the turbo, then winds down next to the cat before going into the intercooler.Does the intake run right above the exhaust on those things? Am I seeing that right?
Edit: I have to put after I posted this I read what you put right above the pic you posted. That's pretty intense they put the intake right there.
I've never seen anyone run an exhaust blanket on an intake. I think the gains would be minimal at best but it could help with heat soak. I'm pretty sure wrap is for controlling radiant heat so I would think once u drive the car for a while you could trap heat in your intake if it starts to get hot. But then again if your only driving short periods of time it could work. This is thinking out loud after a couple beers. Looks cool thats for sure.
cost and efficiency is always the answer. probably something to do with shorter charge piping too. if the piping is longer the turbo takes longer to spool.Yeah, intake pipe right after the airbox(no pictured in second pic) runs above the turbo, then winds down next to the cat before going into the intercooler.
Not sure why the flipped it around on the turbo motors when comparing it to the old n/a K motors.
Yeah.. Sorry about that.Everyone is busy today
Closest to me is 54 miles (1hr 15mins)Good Morning! I found out there's a Benihana near me... and well
I think you know what I'm going to do.
How does one use the reward points???Chick-a-lay, as my oldest calls it.
Really? What a n00b lolHow does one use the reward points???
Asking for a friend...
Come on people... How do you not know about this? Ya'll must never go to Chic-Fil-A.Chick-Fil-A has reward points?!
From one fellow Red Member to another - it's Chick-fil-A.Come on people... How do you not know about this? Ya'll must never go to Chic-Fil-A.
It's been out for years.
Red Status or BUST!
