2012 Civic Audio Wiring Guide & Pinouts For Factory Radio
Hi guys new here. I got this head unit from a salvage yard out of a 15 civic ex for dirt cheap (25 bucks) i think this one is touch screen with out nav. I just need the pin outs for the plugs. Thanks.
See the thread here
What is it going into? I have a 12 Si with the stock non-nav unit and if this is viable I would prefer sticking in a used unit instead of buying a new aftermarket.
Replacing the factory navigation with Chinese android.
New radio
diagram of factory negationis that I found on another forum https://9thcivic.com/forum/threads/2...pinouts.16304/
This 12p cube has nowhere to plug in, and there is probably K1 and K2 in it (if I connect the factory navi without this cube, everything works except for steering wheel control - volume control and channel change)
In CanBus, the K1 is not plugged in anywhere and the K2 seat is empty
In the FAQ at https://www.aliexpress.com/item/4001...yAdapt=glo2pol point 7 and for me these cables are not plugged in anywhere Could someone suggest what to combine with what to make the steering wheel control work?
My factory radio View attachment 64756
New radio
1st are you in the Netherlands? The wiring diagrams on this site are for North America. The civic models outside North America are completely different.
2nd - someone else asked about chinese head units here and said you need something from the radio seller for steering wheel controls.
You may also have more luck at civinfo.com as they cater to civic owners outside North America.
