- 57,201
- 24,273
Yep. People would get pissed when I told them that back when I used to repair devices at Staples.the motherboard stores the original home button/touch id info from what I've read. If you replace the original home button, it will not allow touch id to work, since the motherboard will be looking for the oem button ID. It's stupid, but they say it's for security. It stops someone from essentially stealing an Ipad, swapping out the home button, and then setting up their own fingerprint to use it as their own ipad.
Just googled it. Seems like its that way for the iPad 6. Hope my cousin remembers his password.
Not cheap! FRUGAL!Yeah, but you’re cheap!
Not cheap! FRUGAL!![]()
I'm not sure. I put it together last night and let it charge over night. Tried it this morning. I dont think the screen requires to be fully installed as I saw a video of someone using the screen off the body. I contacted the place I bought it and they said to fully install it but I really don't feel like removing the screen and cleaning the glue off a second time.That absolutely sucks. Is it all in the same spot? Like if something doesn’t open in say the 2nd row of the screen, does the same thing happen in the 2nd row of the next page?
You definitely can use it without it being full assembled. The digitizer should still respond as expected.I'm not sure. I put it together last night and let it charge over night. Tried it this morning. I dont think the screen requires to be fully installed as I saw a video of someone using the screen off the body. I contacted the place I bought it and they said to fully install it but I really don't feel like removing the screen and cleaning the glue off a second time.
when i was testing it i put the screen on with out the backing off the tape so i could remove it again, i didnt realize that the ribbon tapes onto the screen so i was shoving the bezel into the ribbon. i may have damaged it but its working fine now that its installed with the ribbon taped up. should have watched the entire youtube video before messing around with it.Sounds like the ribbon cable has a break or a short.
are gpus easier to get now?My new build
Part List - AMD Ryzen 7 5800X, Radeon RX 6800, Corsair 5000D AIRFLOW ATX Mid Tower - PCPartPicker
Part List - AMD Ryzen 7 5800X, Radeon RX 6800, Corsair 5000D AIRFLOW ATX Mid Towerpcpartpicker.com
Nice build. Look at all that RGB!!!My new build
My 1080Ti has been suiting me just fine as well. I don't game much either, but it seems to take whatever I throw at it pretty well. My monitor is only 1440 though, so it might not do as well when I move to a newer monitor.ive been loving my 1080ti itx build. looks great in the living room and its powerful enough to play some newer games on high. i still barely use it, my kid likes to play spyro.
just installed a xpg gammix s11 pro 1tb nvme, only spot on my MB is on the back so that kind of sucked having to remove everything to install it. the tiny cooler actually fit though which was nice.
