Damn that’s a lot of fans @bootyluvr. For @Janz3n stock setup, not likely an overall airflow problem but a little more air shouldn’t hurt. But definitely sounds like the stock cooler isn’t cutting the mustard. Another problem could be with the IHS, if that’s not seated properly from AMD, then no matter what you do, you’re not going to get cool enough. They had a problem like that with some 5800x processors. Not as likely but still possible, are you getting good contact? How smooshed is that thermal paste when you took the cooler off.
If he gets the new cooler on there and it has warm/hot temperatures then I'd return that 5600X and get another one!
So I replied to that message with the link to MicroCenter for the 5800x at $320 then calculated tax (6% here in MD) for him and gave him the $339.xx total price it was from MicroCenter
