thevietkid33
- 517
new wheels are on :] will post pics up later on tonight. enkei ekm3
yeah. idk for how long tho.looks good. I see you're currently snowless
ehhh i was thinking the same thing. but the wheels def. grew on me. and plus i get a lot of compliment on them, so i guess it looks better in person.Maybe once you get the car dropped it'll help the look of the wheels. The EKM3s were one of my wheel picks but have decided to go with the Sparco Pistas.
4) Coilover collars for the rear of the 2006 Civic will fit right on the 2012 Civic as well, which means the RedShift Koni-based coilover setup that works so well on the 2006 Civic will work on the 2012 Civic as well....from Koni Sport to double adjustable Koni Race setup!
Yes but that's only for rear , the front isint going to work unless you make your own bracket for sway bar , which is probably impossible
iScraped 8th, now iScrape 9th![]()
The 8th coilovers do not fit on the 9th because of the front strut swaybar bracket and the brake line bracket at the bottom.
BUT that is if you are running 8th Civic strut housings.... which we are not. We use the 9thCivic strut housings for our coilovers; so ours will work. Still trying to find someone who will try ours. Last person wrecked their car and had to back out.
Chris
