2012si2012
Hi all, i made a poste about how to change and install HiD kit 9006, but some of the pictures doesnt work. so i will post a new one rigth here in DIY.
sorry for the inconveniense.
sorry for the long picture post!
First you will need the tools!
Rachet+10mm bolt remover
Tierap(at least 4)
Philips screw driver( the star one)
electric tape ( if needed)
the kit you will need its 9006 single beam Hid Kit (in my case i put 10000k
1- First find where are the holes
2-Turn the plug to the left and remove it gently
3-Remove the light from the plug
4-Assemble all the kit together
5-Remove the Bulb cover and insert inside the Headlight----BE CAREFULL TO NOT SCRTCH THE BULB----
6-Connect the power wire to the HiD plug power
7-tierap the ballast firmly to the frame
it can be many way to tierap the ballast in your car.***
8- Test your new kit!
For the battery side... if you want more room to work, remove the bolt that retain your battery.
do the same thing for your other headlight!
Finaly ...ENJOY your work!!
sorry for the other post.
hope that will help it!
thank you.
