forged steel i think hahahaha
... you have to be kidding me.
correct me if i'm wrong... you have to be kidding me.
correct me if i'm wrong![]()
I will gladly oblige.
If wheels were forged steel, BBS and Volk must be doing some pretty insane things with quantum physics to achieve a sub 15lb wheel weight. I'll have to check with BBS to see if they've been using the particle collider at CERN to test new material matrices.
4340 Chromoly steel, a common alloy steel used in forging, has a density of approx 8.03g/cm³. 7075 Aluminum, a common aluminum used in forgings, has a density of approx 2.8g/cm³. That means forged steel wheels would weigh almost 3 times heavier (if we consider the material volume doesn't change). So those Gram Lights 57F wheels you've been drooling over weighing only 6.8kilos (~15lbs) would be around 19kg (~42lbs). I don't know about you, but for 17" wheels, I don't really want to have an additional 12kg (~26lbs) of unsprung mass at each corner...unless of course you want the handling of a loaded down dumptruck.
Most wheels are cast aluminum. High end wheels are forged aluminum. Steelies are stamped steel center with a spun steel barrel. Stamping is cheap, and so is steel...main reason why they are steel
Race wheels are usually 1pc forged aluminum (usually a proprietary alloy), or at the least have forged aluminum centers with a rolled (method of forging) aluminum barrel.
Dedicated racing wheels (centerlocks and such) are usually magnesium or an aluminum/magnesium matrix since aluminum/beryllium matrices are banned. Formula 1 wheels are magnesium, as are the wheels (BBS) used on the Audi LMP cars.
Although magnesium has a higher density than 7075 Aluminum, at approx 3.6g/cm³, it is less brittle, and has less plastic deformation than aluminum, and therefore more material can be machined away - therefore the wheel is lighter.
The end.
The end.
Did I kill the thread? Are there prizes for that?
18lbs for 18x9 is very light, for 18"s lightest so far is 16.5lbs and for 17", 12.5lbs is the lightest i seen
