PapiFlyy
- 525
Front , the rear fits perfect
Sent from Flyy Network.
You tried it ???Front , the rear fits perfect
Thanks for the info ima end up pickin up a set of 8th gen d2 set up if i cant get my friend to lend me the fit shocks from his jobWell the springs fit in rear and I have a 8th also so everything looks the same on rear , the front only thing is the bolt size and the link
good luck with the front broThanks for the info ima end up pickin up a set of 8th gen d2 set up if i cant get my friend to lend me the fit shocks from his job
thanksgood luck with the front bro
Let me see if I understand you...you installed Tokico Blues for a fit on your 9th Gen Civic and they went on correctly? what did you do about the bolt sizes, source new bolts from somewhere? I love Tokico Blues, awesome setup with some quality lowering springs...if this worked props to you! Let me know the answers when you get a chance...thankscheck these out see wat im saying
i was going to but i ended up going with 8th gen d2 suspension just had to order a couple extra things to make it work check my thread on the post aboveLet me see if I understand you...you installed Tokico Blues for a fit on your 9th Gen Civic and they went on correctly? what did you do about the bolt sizes, source new bolts from somewhere? I love Tokico Blues, awesome setup with some quality lowering springs...if this worked props to you! Let me know the answers when you get a chance...thanks
or sell crack!I'm sure most would take one, but most aren't going to drop 7k on a suspension (on a 20k car) unless they're paid to race, or have a lot of spare cash lying around. If its the latter, you'll see more users putting that money into turbocharging.
why would i buy shock that arent dual adjustable and drop my car and lose all that travel on the shock to drive around and blow shocks, pls if spend 7000 on suspension trust i wouldn't be driving in a civic, you talk about koni f1 championships whocares dude you sell that stuff chopped up i would touch that stuff but you didnt see me go on your thread bashing your set up if ppl run your setup ok fine idc its their money i rather buy d2 have dual adjustable plus lifetime warranty and keep all the travel on my shocks and wont be on blown shock
