Gitrdone42
i think the gloss looks good also
Sounds like that would work to me. Especially once it's black. It could hide that pretty well.I messed up when I was drilling out the holes and yes yes, I know I f'd up. I drilled through my door panel. Lesson learned, trial and error. It is what it is. Learning experience. Trying to think of a fix I can do, maybe silicone inside the hole and then paint over it?
nearly done. Thoughts? JB weld does not work at all to stick the plastic tabs back together. I can't put anything back together until I figure this out. Maybe a quick process to heat and melt the plastic together instantly?
I was referring to the parts that you have to drill out. I tried JB weld, but that did not work. To my surprise a cheap glue gun with glue sticks worked much more effectively and everything is actually holding together.
I can’t tell where it’s dented on my phone, but hang in there. See if you can find a paintless dent repair person in your area that is reputable. They can usually get rid of hail damage, door dimples and stuff without issue. It also shouldn’t cost very much either.I ordered the trunk insulator today. I went to drill the holes for the tabs since they were not there and I ended up drilling too far putting a small noticeable dent on the trunk. Totally bums me out, I feel like anything I try doing just puts me back.
It looks like a little dimple, about half way up and centered in the photo. That is a relief it doesn't cost much and hopefully nothing happens with the paint. Just really not trying to have more imperfections than I already have. Thanks Webby! Also, I have been meaning to ask you this for a long time, but what do you drive? Don't think I have ever seen your car.I can’t tell where it’s dented on my phone, but hang in there. See if you can find a paintless dent repair person in your area that is reputable. They can usually get rid of hail damage, door dimples and stuff without issue. It also shouldn’t cost very much either.
