Verzerrung
Does anyone know why my car would still pull to the right? I don't know what else to look for.
The car has always veered off to the right before when the alignment was off and now that it is all aligned it still pulls to the right. I checked my tire pressure and their all at 35 PSI.
I'll go ahead and try this out and see what the result is. Hopefully it fixes it. Thanks for the advice!Not trying to come off as rude or anything but even with brand new tires they can still pull, one way to know for sure if its the tires are causing a pull is to cross rotate the front two tires and see if it pulls the other way. If If it does then you know it's a tire pull and if it's still pulling right its more than likely a alignment/suspension issue.
