DarkKnight38
Member
- 17
- 5
Oops wrong thread.
use #23 if you don't want to be turning things on/offGot it working. Thank you to all the contributors, your help was most appreciated. The only thing I did different was I did not run a relay. I was also having a hard time finding a t-tap. So for now I have it tapped into one of the fuses using an "add-a-circuit" which I already had because I hard wired my radar detector. Only thing that sucks is I have to keep turning off the detector and fogs when I shut off the car cause the fuse box does not turn off when you take the key out (not sure why they designed it like that, so stupid). Once I find a t-tap I will hook up to the ignition wire as in the original post.
what was your issuenvm got it to work!
