Bruce Bartlow
Late apex everything
- 1,599
- 865
- Vehicle Model
- Rented a C8 for a week (what a monster) ended up buying a TLX. Beautiful car inside and out. Killer stereo. Handles better than it should given its weight. Not my dream car, just a Honda Accord in a tux.
- Body Style
- Sedan with the backseat of a two-seater
_______________________________Getting the stock end link off shouldn't be too hard. I've done 2 installs already on NY cars that are all salt corroded and rusty. Best advice is to hit all the nuts with PB blaster penetrating oil and to also take a wire brush and clean the threads before you try and take them off. There will be a ton of crud in the threads and trying to remove the nut will just get it stuck.
I got one stuck and it sucked. If you get it stuck and it just won't come off, try to tighten it back down and clean the threads again. Working it back and forth seems to help if there is a thread that is "boogered" and bent over.
Just brush em like you brush your teeth before you start and it will be much easier.
Clean them up real nice before you put em' back on too. Get all the penetrating oil off.
With a fairly new car (3900 miles) the right end link came right off but the left one (nut) just kept turning like it was stripped. WD 40 didn't work, and was all i had. The other side had the plastic on it so couldn't be held steady.
So if a lubricant doesn't work, the only answer is total destruction?
