Blown spark plugWhat happened?
Could it have been because the car was under a big load? I had 4 people in the car and did a 3rd gear pull when it blew. Idk... But I had it towed to the shop that did my tuning and they'll make sure that's the problem and test the car after replacing the plugs.its weird that you blew a plug. i didn't change my plugs right away. in fact i think i even went to the drag way on the stock plugs. i just changed them because i was already doing the spark plug cover and low profile valve cover hardware.
The only things it really could be is a spark plug, coil pack, injector, or exhaust valve. That's the only things that would cause a misfire in just one cylinder. Hopefully it's a plug or pack :/i doubt it. lets just hope its only a plug
I took the blue off the intake.I can't tell what was painted. Lol.
awsome I can't stop stairing at the supercharger lolDid some cleaning and painting today
Painted the spark plug cover, ecu cover, fuse box cover, and battery tie down.
They all used to be blue.
