Just remember, the convex mirror makes it a little harder to judge just how close you are to things when you're backing up.
That is what a backup camera is for!
Got reverse camera installed yesterday. Think I will go with blue convex one. Not sure if I should go 270 or 300 mm.If you want just a wide view, go with a flat one, but if you want a wider-ER view then go with the convex one. It really helps, I can see outside my rear passenger window with it, it's awesome. Just remember, the convex mirror makes it a little harder to judge just how close you are to things when you're backing up.
I have the 300mm convex tinted. I couldnt go smaller ever, may upgrade to 5 panel in the futureGot reverse camera installed yeterday. Think I will go with blue convex one. Not sure if I should go 270 or 300 mm.![]()
Bigger than 300 seems like over kill no?I have the 300mm convex tinted. I couldnt go smaller ever, may upgrade to 5 panel in the future
I am happy with 300mm but if i do upgrade its gonna run the whole length.Bigger than 300 seems like over kill no?
Got reverse camera installed yesterday. Think I will go with blue convex one. Not sure if I should go 270 or 300 mm.![]()
The vision is large enough? I would like to go with the 270.Personally, I think the 270 is perfect.
I cant see mine from outside the carThe vision is large enough? I would like to go with the 270.
I'm a bit worried that if its too big it kinda looks rice or "young" if you know what I mean.
That looks like the perfect size for me. Thanks for input guys!
I'm soooooo jealous of the Si lit ignition ring. Want that so bad, but in blue.![]()
I have faith that you could make it happenWant that so bad, but in blue.![]()
Already started checking. Haha. You know me well.I have faith that you could make it happen
get the spoon blue tint mirror hell of a wide angle .
yeah its the fd2 mirror go's right over the stock mirror the shape of it gives you a wider view and decreases glareWhat up Paul! Not sure you remember me, met up at Krispy Kreme a few months ago. Anyways, does that mirror just go over the stock mirror? Or, how is it mounted? Looks pretty nifty.
Great picture! We can really see the POV angle that the mirror gives the driver.300mm convex tintedView attachment 28181
