For anyone having shifting issues, I started a thread on one of the other forums, that I thought I would share with you.
So I have been really trying to clean up some sloppiness in my shifter feel. My shifts felt inconsistent, sloppy, and notchy. I installed a Buddy Club SS as my fist mod on the car, almost a year ago. Since then I have done MTEC springs, TWM base bushings, Hybrid Racing cable bushings, and a Hybrid Racing EM1 CMC. I have tried a few different fluids for the tranny as well (right now I am running a Torco MTF/RTF mix). Still frustrated with what I would call a "dead zone" in the shifter. I could wiggle the shift knob and there was a significant amount of slop in the short shifter its self. Well curiosity got the best of me and I decided to tear it apart to look into it. I kept my stock shifter (I have kept every stock part I have removed, glad I did), and upon looking at that, I noticed that there is no play in the shifter its self, it is very solid. Here is a video I took of the wiggle I am talking about with the BC SS:
View: https://youtu.be/SRbCKHzgGKE
This is certainly not normal. There is a lock ring on the top of the cage so you can remove the lever, and that was locked. On the bottom of the assembly, I could see that the plastic that supports the bottom of the pivot ball was broken. I have no idea how long it has been like this, but I have been chasing dragons forever trying to get rid of this. The car only has 11,000 miles so I figured it wasn't cables. I installed the stock shifter and what a WORLD of difference! Absolutely zero play, very precise and predictable shifting, and each gear feels the same. I am not sure if I should contact BC on this issue.
You can see me effortlessly wiggling the lever back and fourth. Beyond the dead zone, you can feel the MTEC springs start to kick in. Once I took the interior panels off the damage was obvious. Here you can see the pivot ball of the shift lever, and how much play it has inside the cage:
View: https://youtu.be/bs8ExTYhg5g
