If you are taking a fuse out and adding this you need two fuses. 1 for the fuse you are replacing and one for the new circuit you are adding.
gonna clean this up nice and easyHey, I fixed images in previous post.
No, I was just using one fuse in one of the slots, didnt realize it required two? So if its going into a 7.5 it should have two 7.5s in it?
Thanks
I wasted over an hour trying to figure that out. Sometimes it's the simplest things that cause the most problems. Haha
Ooooo 15 w fuse. My guess was right.15W LED, 12v @ 1.25A per unit (12v*1.25A=15w)
#18str is good above 5A easily, you're good man!![]()
Yes, I agree with ProCivic. Easiest way to do it is just tapping the wires into parking lights. There are plenty of videos on the net showing how to do this. The lights would only be one when you click once to turn on your
Parking lights or click twice to turn on headlights. Lights would not always be on.
@PRO Civic If he taps into DRA lights, wouldn't they tun off when he puts his head lights on?
SexAwesome, thanks again guys. Everything has been running great since Sunday.
Here is a night time photo:
