Suspension help!
How much lower are we talking?? I plan on 225/45 tires in the future and I don't want rubbing issues. I like where the H&R springs sit.
YOu will be fine..I have the same tires. Regardless there's no rubbing. I dunno how wide youre goin for wheels though.
The back does look lower?
if you look at the bottom edge of the car (below the doors), you can see that it's still a little raked with the front lower than the rear. yes, the rear wheel gap looks a hair smaller, but that's not uncommon. for some reason, on a lot of cars the rear wheel opening is slightly smaller than the front, making the rear look lower even if the car was level. a lot of bmws were like this, even my old e46.
for instance, in this photo, the car's front end is lower than the rear (look at the shadows to tell the level of the car), but the wheel gap is larger in front than in the back. that's cuz the wheel opening is larger in front.
crap that is dead obvious. Yah I can see that car front end is still lower. Interesting.
Wish I had fenders like that on the civic ... LOL
Probably the tire more compressed up front? top line confirms what you were saying.
Just run some spacers. The wheels I have are a +53 but I needed to clear the factory centerbore to run them so I bought 20mm wheels adapters so now they act as a +33 and sit flush :)
Nice colors lol. I have the same minus the KONI sports!
Yah I was debating on getting 10 mm spacer.. Still thinking about it. Was looking at the H&R ones. Meaning more wait time..... grr.. just wanna be done.
If you dont have the yellow you cant be in the laker fan club.....lol....paint your bolts. :rotfl:
Yous guys are crazy! hahaha....
Also: Front wheel well is larger than rear so you can hit bumps with the wheels turned and not hit the fender. Ya?
I assume thats the function behind it. I thought that why H&R other springs have the lower front springs, to compensate?
Remember to have about 8 turns on the lug nuts when using spacers. The civic studs are short be careful. If not press in longer studs.
The rule of thumb with lug nuts is that you need to engage as many threads as the diameter of the lug nut. I don't know the size of the 12'+ civic off hand but it's probably12mm & Honda thread pitch is 1.5mm per thread.
You'll need 8 turns of the nut to engage 12mm worth of threads.
8 turns x 1.5mm = 12 mm of engagement
7 turns x 1.5mm = 10.5mm
6 turns x 1.5mm = 9mm
5 turns x 1.5mm = 7.5mm
Take one off and put it back on until it's tight and see how many turns you get. If it's only 4-5 till it's tight I think you might be running a little short. 7? You're probably ok. I'd say get extended studs with a 5mm spacer just to be safe but check it out and see what it looks and feels like to you. 3mm spacer is usually the max you can safely run.
This is partly why I dont want spacers. Can you just measure the exposed stud with all nuts tightened but one?
