kennyjames
- 88
honestl go 17X9+30 its perfect fitment
helpful siteHey guys I got a 14' Si and I'm lowered on k-tuned coilovers and I closed the wheel gap/well (maybe +2.25"? All around). I'm now contimplating on what size rims I'd like and their respective tire size. I'm definitely keeping the 18" diameter, but I'd like to know what would be an ideal width since I daily drive my car and because I know most aftermarket rims are 8"+. So would an 18x8.5, offset 35-40 be good for me? I also do not want to roll fenders, nor do I want to stretch tires. Thanks in advance!
Thanks a bunch @webby the site helps out a lot.helpful site
http://www.willtheyfit.com/
2014 si oem info to use:
225/40-18
18" rim 7.5" wide +47 offset
It will help to show what tire size changes will be close to keep your speedometer in check. 235/40 is prob the closest thing to keeping your speedo close. It will also show you how changing the offset up and down alters how far in/out from stock it will put you.
I'll definitely look into @Nix thanks for your reply!@chyld_89 - If you're going to run an 18x8.5 the stock 225/40 tire is fine. The widest wheel I'm comfortable putting a 225 on is a 9" wheel. A few people have rubbed a bit with the 225 width and a +35 offset. If you stay at +35 to +45 you should be good. If you're just DD-ing the car a 225/40 on an 8.5" sounds pretty reasonable.
