Thanks! Bought the kit used with around 3-4k miles. Any preventive maintence i should do before installing? Or possible problems to look for?Congrats!
Get plugs that are one step colder if the kit didn't come with any? Flashpro with the CT base map will be needed....umm. ThinkingThanks! Bought the kit used with around 3-4k miles. Any preventive maintence i should do before installing? Or possible problems to look for?
I have new colder NGK plugs And flashpro. Just wondering if I should check anything or perform maintenance on the supercharger itself before install.Get plugs that are one step colder if the kit didn't come with any? Flashpro with the CT base map will be needed....umm. Thinking
CT base map and colder plugs like Webby said.Thanks! Bought the kit used with around 3-4k miles. Any preventive maintence i should do before installing? Or possible problems to look for?
Yes you'll need a new throttle body gasket, you can get a thermal one along with the thermal intake manifold gasket.I have new colder NGK plugs And flashpro. Just wondering if I should check anything or perform maintenance on the supercharger itself before install.
I will need a new intake thermal gasket as the kit didn't come with one and I'm going to buy a new belt. Do I need to replace throttle body gasket? Is there anything else you think i will need to replace?
When I bought my kit, it came with instructions specifically for the 9th gen. I think I may have them lying around somewhere still if needed, I can take pictures of the pages and upload them.I thought they'd have an install guide on their site, but I just see the 2006+ si guide. It should basically be identical. I haven't looked through it, but it should show what to replace as far as gaskets and whatnot? I believe @323 did his install? He may also have input.
http://www.ct-engineering.com/Portals/17/06_Civic_Si_SC_Install.pdf
I'm hoping to tackle all this tomorrow. I should have everything I need and have a friend that can help with the belt. I have a copy of the instructions and have read through them a few times, just waiting on a new belt that should be in tomorrow.When I bought my kit, it came with instructions specifically for the 9th gen. I think I may have them lying around somewhere still if needed, I can take pictures of the pages and upload them.
